AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Prelector
Mar 23, 2018Aspirant
I gave it a good 10 minutes each try to stabilize, but no joy. I didn't do a hard reset, because of the time to readdress things. I'll likely sit at this point with wireless backhaul until I see some empirical evidence it's working in this version.
bbunge
Mar 23, 2018Star
Prelectorwrote:I gave it a good 10 minutes each try to stabilize, but no joy. I didn't do a hard reset, because of the time to readdress things. I'll likely sit at this point with wireless backhaul until I see some empirical evidence it's working in this version.
I did not do a factory reset coming from firmware 2.2 beta with my RBK50. I did the upgrade to the satellite, RBS50 over WIFI backhaul with the satellite about 40 feet from the router. When the satellite started to reboot I started the upgrade of the router, RBS50. Once both were stable I shut the satellite down and connected the ethernet cable, direct wired to the router. Took a few minutes for the satellite to get the wired backhaul connected but it was a stable connection. I did a reboot from the web gui of the system and the wired connection came back up. I did use a purchased CAT5 cable that is marked as certified. I would strongly recommend you test any cable you fabricate. GIG ethernet can be unforgiving with a bad cable.
