AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
bbunge
Mar 23, 2018Star
Prelectorwrote:I gave it a good 10 minutes each try to stabilize, but no joy. I didn't do a hard reset, because of the time to readdress things. I'll likely sit at this point with wireless backhaul until I see some empirical evidence it's working in this version.
I did not do a factory reset coming from firmware 2.2 beta with my RBK50. I did the upgrade to the satellite, RBS50 over WIFI backhaul with the satellite about 40 feet from the router. When the satellite started to reboot I started the upgrade of the router, RBS50. Once both were stable I shut the satellite down and connected the ethernet cable, direct wired to the router. Took a few minutes for the satellite to get the wired backhaul connected but it was a stable connection. I did a reboot from the web gui of the system and the wired connection came back up. I did use a purchased CAT5 cable that is marked as certified. I would strongly recommend you test any cable you fabricate. GIG ethernet can be unforgiving with a bad cable.
WAP
Mar 23, 2018Apprentice
Do not believe the WEB GUI when trying to determine if ethernet backhaul is working. Download SPEEDTEST app to your phone and place your phone next to ethernet connected satellite. Even after several minutes the WEB GUI isn't sinking properly (for me) but each of my two wired ethernet satellites is getting 400 Mbps Up and Down (I have a 1000 Mbps service which I can only get when directly wired into my router)
