AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Mar 23, 2018Guru - Experienced User
I highly recommend doing a Factory reset after installing the beta FW. This probably has major changes and updates to the code. To ensure the beta FW is installed and seated well and to give it a solid chance, a factory reset should be performed and set up from scratch. I can attest to ethernet back haul IS working on my Orbi system. Factory reset performed and then set up from scratch. Two non managed Gb network switches between my 1 Satellite and the Orbi router.
Give the new FW a chance. Take the time and do the reset and set up from scratch.
