AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Mar 23, 2018Guru - Experienced User
I highly recommend doing a Factory reset after installing the beta FW. This probably has major changes and updates to the code. To ensure the beta FW is installed and seated well and to give it a solid chance, a factory reset should be performed and set up from scratch. I can attest to ethernet back haul IS working on my Orbi system. Factory reset performed and then set up from scratch. Two non managed Gb network switches between my 1 Satellite and the Orbi router.
Give the new FW a chance. Take the time and do the reset and set up from scratch.
b1ggjoe
Mar 23, 2018Apprentice
I’m curious:
Doesn’t Orbi have a way to Export a config file of all of our settings, that we can simply reimport after a Factory reset?
Even if it does, I wonder then, if by doing so would just eliminate any of the benefits of doing a Factory Reset to begin with?
Also, is it just me or is it that we can only disable SSID Broadcasting from the Guest Network, but not from the main WiFi Network?
They also need to add a way to force WiFi devices to only connect to either 2.4GHz or 5GHz.
BJ
BJ
- FURRYe38Mar 23, 2018Guru - Experienced User
Yes under Advanced/Backup settings. Under normal circumstances and with in the same version of FW, this back up file is valid. However after updating FW from one version to the next major version, there maybe some items with in the new FW that could have adverse operations if a older config file is applied from a prior version of FW. So, with this, I recommend after upgrading to the next major version of FW or Beta or from Beta to official releaed FW. Do a factory reset, set up from scratch and then save off a new back up config file for this next version thats loaded. Then you have a good back up for the current version of FW that your working with. Seen odd issues over the years in working with routers and configurations and many different FW versions. All this lead me to just take the plunge and do a resets then set up from scratch and make a new backup config file at each upgrade stage in the FW cycle. I presume when the FW become more stable and all non beta official FW, you mgiht be able to just upgrade the FW and any current configurations should remain and persist which is NG normal idea of upgrading FW.
You should be able to disable the main wifi radios under Advanced/Advanced/Wireless settings. Is this what your looking for?
The Orbi system is designed Smart Connect. It's supposed to handle which devices get connected to which freqency based on device support and operation automatically. So this feature isn't supposed to rely on any user intervention.
b1ggjoewrote:
I’m curious:
BJ- b1ggjoeMar 23, 2018ApprenticeAaah ok, makes sense. As far as the WiFi question, I was just trying to hide and keep the SSID from broadcasting, not so much disabling the radio.
I see where this can be done for the Guest Network, but not the main WiFi SSID.- larryindublinMar 23, 2018LuminaryAdvanced
Advance setup
Wireless
Options to broadcast SSID are there.
- varaseMar 29, 2018GuideLong ago (with my R6000) I advocated that NetGear export parameter settings in an XML file so only selective keywords/parameters could be imported on reload, but NetGear was at best lukewarm to the idea.
I think that an XML export would allow for a more reliable import of old setting because a given firmware level could import what it understood and ignore anything it didn’t.
What’s more, even if the binary blob which represents the settings changed format, a relates of the text dumped parameters would be unaffected.
— Verne- FURRYe38Mar 29, 2018Guru - Experienced User
Well since then I presume NG hasn't changed there decision about this. I presume they wont as it may be a security concern that they don't want to really mess with. I presume if they haven't done anything since then, they probably won't now.
— Verne
- RocketSquirrelMar 23, 2018Luminary
Even if it does, I wonder then, if by doing so would just eliminate any of the benefits of doing a Factory Reset to begin with?It is worrisome that the exported .CFG file is binary and not text. To me, that suggests that importing the .CFG will, as you say, eliminate the benefits of a factory reset because it's just reading old settings back into memory. If the .CFG file were text, at least we would know what was in there and understand that the firmware was interpreting the old settings from text back into binary.
For security reasons, I presume, the config file isn't open text anymore. Most router Mfrs don't use clear text files anymore.
