AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
quaningeneva
Mar 24, 2018Apprentice
I have a linear configuration: Router-Sat1–Sat2. I cannot get Sat2 to connect to Sat1 in daisy chain configuration. Any way to force this? Sat2 and Router are at opposite ends with Sat1 in the middle.
Miles267
Is there a newer version for the RBS50Y Outdoor Satellite also?
- j1nMar 26, 2018ApprenticeI have the same question: Does the Orbi Outdoor satellite (RBS50Y) work with the 2.1.3.4 Beta firmware. The current firmware version of the RBS50Y I have is: v2.1.2.20
I believe AmitR mentioned that the firmware number for the router and each satellite should be the same to the 3rd digit. I’m wondering if that applies to the RBS50Y as well?
