AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Csanderson0628
Mar 24, 2018Guide
I just bought this system a couple of days ago and getting ready to send back. It will keep disconnecting and the download speed is lower then what it should be. Any way to fix these issues before I send it back?
Thank you
Thank you
larryindublin
Mar 24, 2018Luminary
Thank you
Well, give the beta firmware a try for sure. Only for the RBR50/RBS50 (RBK53 set) for now. I was stable with previous firmware but many others had issues.
