AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
bbunge
Mar 24, 2018Star
Csanderson0628wrote:
I just bought this system a couple of days ago and getting ready to send back. It will keep disconnecting and the download speed is lower then what it should be. Any way to fix these issues before I send it back?
Thank you
Try the new "beta" firmware. See the first post in this series...
WAP
Mar 24, 2018Apprentice
Was rock solid on .18 firmware. Tried the beta and now the GUI isn't showing the satellites properly. Reset the satellite back to factory and gave it a couple of hours for it to "settle down". That didn't work. Going to reset router and satellite and see if the beta is at least as good as .18
- chsalmonMar 24, 2018Apprentice
installed this beta (V2.1.3.4) 6 hours ago, factory reset router RB50 and satellite , and now when i look at debug.htm,
System uptime is 00:50:35 !!! Why the system uptime reset to zero many times per days !? router reboot !?
Basic Infomation CPU Load 11.7506% Memory Usage(Used/Total) 171MB/495MB Flash Usage(Used/Total) 32MB/4GB Network Session(Active/Total) 1122/65536 System Uptime 00:50:35 this was same with all previous version.
The system is not supposed to reboot !
- FURRYe38Mar 24, 2018Guru - Experienced User
You need to reset both Router and Satellites for the new FW to take good full effect. Set up from scratch.
WAPwrote:Was rock solid on .18 firmware. Tried the beta and now the GUI isn't showing the satellites properly. Reset the satellite back to factory and gave it a couple of hours for it to "settle down". That didn't work. Going to reset router and satellite and see if the beta is at least as good as .18
