AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
bbunge
Mar 24, 2018Star
Csanderson0628wrote:
I just bought this system a couple of days ago and getting ready to send back. It will keep disconnecting and the download speed is lower then what it should be. Any way to fix these issues before I send it back?
Thank you
Try the new "beta" firmware. See the first post in this series...
Csanderson0628
Mar 24, 2018Guide
I did try that link to update it but it would not take that update.
- FURRYe38Mar 24, 2018Guru - Experienced User
What model Obri system do you have? This beta is for the RBR50 and RBK50 systems only.
If you have the 50 system, use IE11 or FF browser to send the FW file. Besure your wired with the Satllite and router when you upgrading FW. DO NOT USE Wireless!!!
I did try that link to update it but it would not take that update.- Csanderson0628Mar 24, 2018GuideI have a rbk33
The beta FW is for #50 models only right now. Other models are on the way. Please be patent.
I have a rbk33
