AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Mar 24, 2018Guru - Experienced User
Besure that you preformed a factory reset after loading the beta FW on BOTH router and Satellite. Then set from scratch.
Placement is crucial as well. Mines about 40 feet disstance between the router and satellite.
srinivas29wrote:Upgraded to the Beta Firmware for both the router and satellite. The satellite is connected to router in 2.4 GHZ and the connection is poor. Any solution for this, other than moving the satellite closer to the router. Satellite is exactly in a floor below the router.
srinivas29
Mar 24, 2018Aspirant
I did for the satellite, I will have to do for the router. By Factory reset i hope you are asking me to hold the reset button on back of the router for 5 secs?
