AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
guzzijason
Mar 24, 2018Apprentice
srinivas29wrote:Upgraded to the Beta Firmware for both the router and satellite. The satellite is connected to router in 2.4 GHZ and the connection is poor. Any solution for this, other than moving the satellite closer to the router. Satellite is exactly in a floor below the router.
You should try moving the satellite, at least as a troubleshooting measure. 5 GHz is absolutely terrible at penetrating walls/floors, so it's not terribly surprising to me that 2.4 GHz might win in this situation.
dpdurst
Mar 24, 2018Luminary
Been running fine on the 2.1.2.18 firmware, upgraded this morning about 4am and no issues with the upgrade, router, sat or devices. Been running fine so far. Will continue to monitor
