AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Jeremyinsf
Mar 26, 2018Apprentice
I did not have any problems with previous version, but I went ahead and updated to the beta.
Now on the satellite I am getting disconnects... but just one device. It's a La Crosse c84343 weather station. It constantly (like once a minute) disconnects and then comes back online and requests DHCP address. My log is now filled with DHCP messages from that device. If it helps, that device is quite close to the satellite.
I have not done a hard reset of the satellite - I will do that next.
So far, this seems to be my only issue with the beta (knock on wood) but like I say, this is a new issue.
- wchpMar 26, 2018Luminary
Jeremyinsfwrote:Now on the satellite I am getting disconnects... but just one device. It's a La Crosse c84343 weather station. It constantly (like once a minute) disconnects and then comes back online and requests DHCP address. My log is now filled with DHCP messages from that device. If it helps, that device is quite close to the satellite.
This issue is particular to the La Crosse weather station. For whatever reason, it gets very confused when both a 2.4G and 5G share the same SSID.
If you call their support line and chat a bit you will hear this about other routers and brands that share a common SSID. The trick to get it working again is to turn off the SSID broadcast for 5G (under Advanced wireless setup), then factory reset the La Crosse, link it up to the 2.4G SSID (which is the only one now being broadcast), power cycle the LaCrosse once the setup is complete and then re-enable SSID broadcast on 5G.
Make sure you are running the latest firmware on the LaCrosse as well.
This is not an Orbi issue but rather a LaCrosse issue that they are aware of.
- JeremyinsfMar 26, 2018Apprentice
Thanks for the info. Will definitely do what you suggest. However - why is this now a problem with the Orbi firmware update, when I had no problems before?
- steve8411Mar 26, 2018Apprentice
My guess is there is something wrong with DHCP ....
You cannot set lease times ... which, at my office, days after people are gone, their device still shows up as "connected"
So far, my Ipad has not had a problem after giving it a static IP.
- guzzijasonMar 26, 2018Apprentice
steve8411wrote:My guess is there is something wrong with DHCP ....
The default DHCP lease time on the Orbi is 1 day (86400 seconds). It can be changed, but you need to be on the command line to do it:
# config set lan_lease=86400 # config commit [ now reboot the router to apply]
Just change the default value to whatever you want... with the usual caveat that if you are poking around on the command line and not sure what you are doing, you may just make things worse for yourself; but nonetheless, the option is there for those intrepid types.
EDIT TO ADD: I'm not sure that extending the DHCP lease time will actually fix anything in regards to the intermittent connectity drops that some clients seem to have. Personally, I prefer a longer lease time, but I've seen clients drop their connetion well before the current lease expires.- WizecMar 26, 2018Apprentice
Still seeing lots of disconnects on iPhone 7, iOS 11.2.6 even after trying this beta since about an hour after it dropped online. Very disappointing. I’ve tried every tweak and combination of tweak that exists on this forum, which I’ve haunted for about 9 months now.
- FURRYe38Mar 26, 2018Guru - Experienced User
Do a reset on both Satellite and router.
Also can try disabling MIMO, Daisy Chain and Fast Roaming to see if this helps any.
Jeremyinsfwrote:I did not have any problems with previous version, but I went ahead and updated to the beta.
