AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Retired_Member
Mar 26, 2018I installed the new BETA for the RBKR50 and RBKS50 but Circle is not working, I stay in the loop when trying to enabling Circle on the router.
- chsalmonMar 26, 2018Apprentice
Hi again... (last for today :-) )
i've connected my satellite with wire via BPL (powerline devolo), it too far to use a real wire.
Will see tomorrow if it works better or not...with wire backhaul
i think you know that orbi's connected device page is very buggy, i have too many device in the list, and one is connected to my satellite (with wifi , that's ok) and to my router (with wire ! false ).
- Chairman007Mar 26, 2018StarI can confirm that Circle is working once enabled on RBR50 & RBS50.
- Retired_MemberMar 26, 2018Did you do something to get it enabled? I keep getting the error seen in the attachment.
- Streak2Mar 26, 2018Master
Retired_Member wrote:
Did you do something to get it enabled? I keep getting the error seen in the attachment.I loaded the beta firmware, did not do an resets and I was able to enble Circle with no problem.
