AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Chairman007
Mar 26, 2018Star
I can confirm that Circle is working once enabled on RBR50 & RBS50.
Retired_Member
Mar 26, 2018Did you do something to get it enabled? I keep getting the error seen in the attachment.
- Streak2Mar 26, 2018Master
Retired_Member wrote:
Did you do something to get it enabled? I keep getting the error seen in the attachment.I loaded the beta firmware, did not do an resets and I was able to enble Circle with no problem.
- wchpMar 26, 2018Luminary
Retired_Memberwrote:
Did you do something to get it enabled? I keep getting the error seen in the attachment.SayD1984,
Are you trying to do this with the app or have you tried doing it from the Web GUI?
Your attachment is showing the app... I would suggest trying to enable it from the Web GUI/Interface from your PC instead.
