AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Jeremyinsf
Mar 26, 2018Apprentice
I did not have any problems with previous version, but I went ahead and updated to the beta.
Now on the satellite I am getting disconnects... but just one device. It's a La Crosse c84343 weather station. It constantly (like once a minute) disconnects and then comes back online and requests DHCP address. My log is now filled with DHCP messages from that device. If it helps, that device is quite close to the satellite.
I have not done a hard reset of the satellite - I will do that next.
So far, this seems to be my only issue with the beta (knock on wood) but like I say, this is a new issue.
Mar 26, 2018Guru - Experienced User
Do a reset on both Satellite and router.
Also can try disabling MIMO, Daisy Chain and Fast Roaming to see if this helps any.
Jeremyinsfwrote:I did not have any problems with previous version, but I went ahead and updated to the beta.
