AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Mar 27, 2018Guru - Experienced User
Yes, there will be many issues with routers, PCs and software. Endless cat and mouse game.
I don't see anything related to upnp on those two artcles though.
For anyone wanting to test there router out, try this to check for any upnp issues:
https://www.grc.com/x/ne.dll?bh0bkyd2
Good Luck.
- WizecMar 27, 2018Apprentice
The articles I linked last time were merely to illustrate that while direct attacks are not often targeted at the individual, router security is still an important element of security.
I can see how the way my answer was formatted might have been a bit confusing though.
Ironically, you linked to www.grc.com which I am very familiar with and almost linked myself before I thought I would just drop the topic. You might want to take notice of the following:
“The UPnP protocols were never designed to be exposed to the public Internet, and any Internet-facing equipment which does so should be considered defective, insecure, and unusable. Any such equipment should be disconnected immediately.”Quoted from the UPnP Exposure Test page at:
- FURRYe38Mar 27, 2018Guru - Experienced User
Well maybe for some. However in most cases some users need the use of uPnP. For me I do espeically in gaming. Again, ZERO issues in using it over the years. All up to the users I guess.
Good Luck.
