AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
wong_wj
Mar 29, 2018Aspirant
Have to factory reset satellite and all is well. RBR50 with RBS50 on Ethernet and RBW30 on 5G.
But I have another issue. My RBR50 is behind another router ASUS AC68U so the internet port is not in use.
Internet shows error not connected which is fine.
But the router failed to connect to NTP server and QoS setup fail to connect to speedtest.
- FURRYe38Mar 29, 2018Guru - Experienced User
use the DMZ on the ASUS router for your Orbi router if your using the Orbi router in router mode. The DMZ will help with being in a double NAT condition.
wong_wjwrote:Have to factory reset satellite and all is well. RBR50 with RBS50 on Ethernet and RBW30 on 5G.
