AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Mar 30, 2018Guru - Experienced User
Was a full factory reset performend after applying the Beta FW on both router and satellite
steve8411wrote:Well, this version is not ready for prime time.
Again, I’m noticing drops requiring power cycling WiFi only on my iPad to restore connectivity. Also other apple iPads...
nothing on my other WiFi devices...
? Then set up from scratch?
What iOS versions are you using on the apple devices?
What wireless channels are you using? Try manual 1, 6 or 11.
Try WPA2 and AES only.
Disable the following:
MIMO, Daisy Chain and Fast Roaming and test.
steve8411
Mar 30, 2018Apprentice
No factroy reset ...
I (like others) dont believe that a factory reset should be a necessity. Especially in my case where I have a long list of port forwarding going on ...
iOS 10 on an older iPad and 11.x on the rest ...
