AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
steve8411
Mar 30, 2018Apprentice
No factroy reset ...
I (like others) dont believe that a factory reset should be a necessity. Especially in my case where I have a long list of port forwarding going on ...
iOS 10 on an older iPad and 11.x on the rest ...
Mar 30, 2018Guru - Experienced User
Please do a full factory reset and set up from scratch on both router and satellites. While normal official released FW would follow not resetting, this is a Beta FW which probably has major improvements to the code which needs a good clean slate to start from. Doing a reset allows for the code to be seated well and given a chance to work well. You can do a new configuration to file after setting it up for this version of FW as well for later use.
Others have seen follow on problems after updateing however the problems went away after doing a reset and setup again.
steve8411wrote:No factroy reset ...
