AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Mar 30, 2018Guru - Experienced User
Glads it working now.
Is there a router in front of the Orbi router?
diarmuidmawrote:
Yes I did a full reset and only worked in the end after switching to ap mode
diarmuidma
Mar 30, 2018Star
Yes there is a router in front of it wifi has been rock solid since.
- FURRYe38Mar 30, 2018Guru - Experienced User
Ok.
You can use the 1st routers DMZ feature if you want to try using the Orbi in router mode later on.
Enjoy.
diarmuidmawrote:
Yes there is a router in front of it wifi has been rock solid since. - globespyMar 30, 2018Apprentice
I'm at a week and not a single issue with v2.1.3.4
Didn't do any paperclip hard reset.
It just works.
Like others I am seeing what I am assuming are false Dos Attacks in the log?
Would be nice to not have these, anything I can do to get rid of the false positives or know if any of them are real?
I used whois lookup and the IP addresses were from all over the world. So it is a little concerning, but hasn't impacted performance
