AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
srgb111
Apr 01, 2018Guide
What is the best procedure to set up a system w/ wired backhaul? I can't seem to get the system to fully recognize the sats with wired backhaul. To even get close I need to turn off daisy chain, sync with the sats unpluged, and then once the system is stable on the wireless side plug everything in...eventually it will start reporting wired backhaul, but even jumping through hoops like this the GUI never reports stable connections to the sats. Is there an optimal procedure that repeatably gets this to a stable, wired system?
I really can't understand how this wouldn't be tested even for a beta - did they really not factory reset, turn on the RBR, plug in ethernet, turn on RBS and sync? I'm not trying anythng remotely complicated here - so it's shocking to me that it doesn't just work...
stangebelm
Apr 01, 2018Guide
Bei mir läuft seit dem letzten Update alles für mich korrekt und stabil vor allen Dingen !
Die Task-Force von Netgear hat ja wohl auch etwas gebracht!
Endlich nicht mehr jeden Tag Gedanken machen um sein Internet bzw WiFi Verbindung!
Ich habe das rbk50 + den RBS 40 + den RBS30😁🍻
