AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
AmitR
Apr 02, 2018NETGEAR Employee Retired
I can confirm, we've begun pushing 2.1.3.4 available for auto-upgrade. Feel free to upgrade using mobile app / WebUI.
Orbi Product Management
jgehlhaar
Apr 02, 2018Aspirant
Dear Orbi Product Mgmt --
So the latest auto push you made broke wired backhaul for me. Is that a known issue? When do you plan to fix this?
- jeff
- FURRYe38Apr 02, 2018Guru - Experienced User
Did you do a factory reset then setup from scratch?
After setting up the Satellite on wirless first and it's working, then connect the ethernet cable for wired back haul, give 2-50 minutes for the system to re-configure for wired back haul. Should come back. Mines working as is others.
There any network switches between the router and satellite?
jgehlhaarwrote:Dear Orbi Product Mgmt --
- jeff
