AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 02, 2018Guru - Experienced User
What is the distance between the Satellite and Router? Mines 40ft est.
Manual channel 48.
What channels are you using?
FYI, managed switches will cause problems with wired back haul if and when you try this.
- CyberExorcistApr 02, 2018Star
Manual channel 48.
Maybe 25' at the most. I'm using Manual Channel 48 and 11 for 2.4, had 2.4 set to auto, but tried this to see if it would make a difference. I just turned my satellite back on. We'll see how long it lasts this time.
- FURRYe38Apr 02, 2018Guru - Experienced User
25 feet seems to be a bit close. Normal stand alone routers can handle this kind of range by themselves. You might see if you can place the Satellite at a farther distance. Also might test just the router alone.
Also try disabling MIMO, Daisy Chain and Fast Roaming.
FURRYe38wrote:25 feet seems to be a bit close. Normal stand alone routers can handle this kind of range by themselves. You might see if you can place the Satellite at a farther distance. Also might test just the router alone.
MIMO and Fast Roaming were already off. I turned off Daisy Chain. It might be a bit farther than 25 feet. Nonetheless, when I have my satellite off, I get a lot of 2.4G connections. With it on everything above the basement gets on 5G. I also reset the backhaul password.
I see they are releasing 2.1.3.4. I thought this was beta? Did they not change anything from the beta software, and just release it? If that's the case, the beta software is the real software as there are no revision changes based on the numbering.
