AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 03, 2018Guru - Experienced User
What mfr and model# is your ISP modem? There a built in router here by chance?
Perform a full factory reset on both router and satellite(s) then set up from scratch.
Sevo123wrote:
Had so much issues with my last rbk53 unite netgeAr told me go return it get a new one. So i did and everything works well over 2 months they close the case and oh nooo **bleep** hit the fan! Same issues starts without any settings or firmware changes! Smh !!!! So they re open it get me to update to this latest firmware but guess what yall I am supposed to get 400-480 mbps i get a constant 250-280 mbps hard wired or wireless. Direct from mu modem im getting 480mbps on this rbk53 with this update its half. The last update which worked for 2 months i got a excellent 400-480 mbps constantly till it crashed. Whyyyyyyyyy Netgear WHYYYYYYYY! Fix all your bugs already we are sick of this honestly! Look at the speed difference from now & 1 month ago.... smh
Sevo123
Apr 03, 2018Apprentice
Its a motorola or arris and no wifi on it. Its just then modem. It also got replaced just incase it was the modem but same thing.
