AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 03, 2018Guru - Experienced User
How big is your home?
What is the distance between the router and satellite?
What is the Mfr and model# of the ISP modem the Orbi router is connected too?
Any other wifi neighbors near by? If so, how many?
Try setting manual channels on 2.4ghz to 1, 6 or 11.
Disable MIMO, Daisy Chain and Fast Roaming on the router.
joelinhowrote:
FURRYe38wrote:I agree, wish NG would allow users to choose auto update or not.
Please try the full factory reset then set up from scratch on everything.
joelinhowrote:Yes that is my intention. But not so easy for my wife and kids that get home before me and find a network that is not working because of this auto update. Would have been nice if I could control when to update to minimize suffering due to angry wife and kids.
What is the full factory reset? I have pressed the reset button twice on the satellite and I have initiated factory reset in the gui for the router + one reset button press after that. Is there something else that I can do?
The status on my orbi system right now is worse than it has ever been. I have had problems with the connection between satellite and router since day one, but the router has always been stable. Worst case I shut off the satellite and used wifi from router. But right now the wifi from the router is dropping in and out. The only stable connection I have is when wired to the router. Right now I am thinking of going back to my old Asus router just to have a working wifi network.
joelinho
Apr 03, 2018Apprentice
FURRYe38wrote:How big is your home?
My house is not that big. 3 stories, 150 square meters. Router on middle floor and satellite down below. A couple of meters apart with some floor and walls between. Ofc I got neighbours with their own wifi networks, but who doesnt? These systems must be build to handle some interference from other networks.
Anyway. I just downgraded to my old firmware, V2.1.2.18, and it has been stable since then. If I knew I could stay on that I would be happy but the auto update will soon bring me back to the non working firmware. I think I need to look into returning this product and buying something else.
- FURRYe38Apr 03, 2018Guru - Experienced User
wireless will always have problems with nieghbors and intererences. Nature of the beast.
Ok. Sounds like have your results. Good Luck in your endeavours.
