AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
bsholbrook
Apr 04, 2018Apprentice
Our Orbi system worked perfectly on the last production firmware. On this latest firmware and a factory reset our HomeKit home automation setup has become unreliable. Inevitably the ecobee system, casetta, or hue will show offline / no response now.
- FURRYe38Apr 04, 2018Guru - Experienced User
Try disabling Beamforming, MIMO, Daisy Chain and or Fast Roaming?
bsholbrookwrote:
Our Orbi system worked perfectly on the last production firmware. On this latest firmware and a factory reset our HomeKit home automation setup has become unreliable. Inevitably the ecobee system, casetta, or hue will show offline / no response now.- bsholbrookApr 04, 2018ApprenticeAll of these options are already turned off
I would revert back to what was working then. Reset and set up from scratch.
