AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 04, 2018Guru - Experienced User
I recommend using the modems DMZ for your Orbi router while in router mode. This will help with any double NAT issues.
Yes, the reason your Orbi router sets up 10.x.x.x is that your ISP modems is using the same default 192.168.1.1 that most NG routers use. So during setup, the wizard will change the NG routers IP address pool to not conflict with the modesm IP address pool. You can change from 10.x.x.x to 192.168.0.1 if you like.
Havok_wrote:Just want to put it out there that I do use this sytem in Router mode, but I have it behind my ATT router (the ATT wireless is turned off and mine is hard wired to it and hands out wireless to the house on the 10.0.0.x network).
It's too bad this site doesn't have an option for user surveys. It'd be helpful if we knew problems were predominantly on systems in an early mfg run and/or how they were set up. Mine was purchased from Amazon at end of June 2017.
Havok_
Apr 04, 2018Star
FURRYe38, thanks for the tip. I should have clarified. I'm not having any issues at all so far. Everything works great for me (knock on wood).
Still, I like the idea of placing the Orbi in DMZ since it's handling NAT anyway. Thanks!
- FURRYe38Apr 04, 2018Guru - Experienced User
Ya you'll be fine to use the DMZ. If your not seeing any other issues. Don't reset for now.
Havok_wrote:FURRYe38, thanks for the tip. I should have clarified. I'm not having any issues at all so far. Everything works great for me (knock on wood).
