AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
eljarviso
Apr 04, 2018Luminary
"Provides protection for the MDNS packet flood issue"
Please check into this protection. Since installing this firmware I'm having nothing but problems with Apple Homekit devices that connect via Wifi/Ethernet (bluetooth devices that connect to my appletv homekit hub are OK). The devices flap between "No Response" and online in the Home app.
- FURRYe38Apr 04, 2018Guru - Experienced User
What FW version were you using before?
Has a factory reset been performed after you updated to this Beta? If not, please factory reset both router and Satellite(s) then setup from scratch.
eljarvisowrote:"Provides protection for the MDNS packet flood issue"
- eljarvisoApr 04, 2018Luminary
Already did a factory reset. I was using whatever the last stable 2.0 firmware was. With all the **bleep**ing around i've had to do with this piece of **bleep** i'm thinking of grabbing an old Cisco ASA5505 from work and using the Orbis strictly in AP mode.
Can let us know if that resolves your issue. Or revert back to last working version of FW.
eljarvisowrote:Already did a factory reset. I was using whatever the last stable 2.0 firmware was. With all the **bleep**ing around i've had to do with this piece of **bleep** i'm thinking of grabbing an old Cisco ASA5505 from work and using the Orbis strictly in AP mode.
