AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 04, 2018Guru - Experienced User
What FW version were you using before?
Has a factory reset been performed after you updated to this Beta? If not, please factory reset both router and Satellite(s) then setup from scratch.
eljarvisowrote:"Provides protection for the MDNS packet flood issue"
Please check into this protection. Since installing this firmware I'm having nothing but problems with Apple Homekit devices that connect via Wifi/Ethernet (bluetooth devices that connect to my appletv homekit hub are OK). The devices flap between "No Response" and online in the Home app.
eljarviso
Apr 04, 2018Luminary
Already did a factory reset. I was using whatever the last stable 2.0 firmware was. With all the **bleep**ing around i've had to do with this piece of **bleep** i'm thinking of grabbing an old Cisco ASA5505 from work and using the Orbis strictly in AP mode.
- FURRYe38Apr 04, 2018Guru - Experienced User
Can let us know if that resolves your issue. Or revert back to last working version of FW.
eljarvisowrote:Already did a factory reset. I was using whatever the last stable 2.0 firmware was. With all the **bleep**ing around i've had to do with this piece of **bleep** i'm thinking of grabbing an old Cisco ASA5505 from work and using the Orbis strictly in AP mode.
- eljarvisoApr 04, 2018Luminary
Same problem. I'm going to revert back to last stable i was using 2.1.2.18.
FURRYe38wrote:Can let us know if that resolves your issue. Or revert back to last working version of FW.
Ok. Let us know if it fixes your problem. I would contact NG support about this and let them know. Might send a PM to the forum moderators on here as well.
Good Luck.
eljarvisowrote:Same problem. I'm going to revert back to last stable i was using 2.1.2.18.
