AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 04, 2018Guru - Experienced User
Try disabling Beamforming, MIMO, Daisy Chain and or Fast Roaming?
bsholbrookwrote:
Our Orbi system worked perfectly on the last production firmware. On this latest firmware and a factory reset our HomeKit home automation setup has become unreliable. Inevitably the ecobee system, casetta, or hue will show offline / no response now.
bsholbrook
Apr 04, 2018Apprentice
All of these options are already turned off
- FURRYe38Apr 04, 2018Guru - Experienced User
I would revert back to what was working then. Reset and set up from scratch.
