AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 03, 2018Guru - Experienced User
Go in and set a static IP address ON the printer or set up a reserved IP address ON the router for the printer.
Might check to see what modes and security settings the printer supports. Some don't support AES. Try setting a manual channel on 2.4Ghz to 1,6 or 11.
Chairman007wrote:
Couple of quick ones:
- Is the officially released firmware v.2.1.3.4 for RBR50 & RBK50 different in any way from the beta version offered previously? Reason I ask is that my HP printer disconnects from the RBR50 router, whether connected by wireless or an Ethernet connection. Only fix has been to power cycle the printer to reconnect. My system has been stable with this one exception which was never an issue prior to beta/official v.2.1.3.4
- Is it ok now to add my RBW30 plug-in satellite back in? If so, what firmware should be applied to work properly with the RBK50 devices at v.2.1.3.4?
Thanks.
Chairman007
Apr 04, 2018Star
Hi Furry ... just some feedback. I was assuming that the orbi stability issues were the cause of my printer disconnecting. Wasn’t able to fix it by the latest beta which fixed all other stability issues. Solved by resetting the HP Officejet 6968 to factory condition and removing and reinstalling software. All A-ok now ... no longer disconnecting.
- FURRYe38Apr 04, 2018Guru - Experienced User
Awesome, glad it was the printer config. Seems like some things needs a reset. LOL.
Glad you got it working. Enjoy. :smileywink:
