AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 04, 2018Guru - Experienced User
Thanks for letting us know.
eljarvisowrote:Downgraded firmware and didn't do a factory reset and everything is back to normal. HomeKit Ethernet/Wifi device queries occur instantly. This is running the Orbi in full router mode. This pretty much confirms 2.1.3.4 borks HomeKit mDNS.
bsholbrook
Apr 04, 2018Apprentice
I’ve had my share of HomeKit issues with this new firmware myself. I moved the HomeKit hub between Apple TVs and its re-stabilized for the time being. I’m not holding my breath, but hoping this helps.
- FURRYe38Apr 04, 2018Guru - Experienced User
Have you tried disabling Beamforming, MIMO, Daisy Chain and or Fast Roaming?
What hub device are you using for home kit?
Are the Apple TVs using a dynamic or static IP address. My one ATV is set on a Static IP address outside of the rourters IP address pool.
bsholbrookwrote:I’ve had my share of HomeKit issues with this new firmware myself. I moved the HomeKit hub between Apple TVs and its re-stabilized for the time being. I’m not holding my breath, but hoping this helps.
- bsholbrookApr 04, 2018Apprentice
All three Apple TVs in the House are dhcp clients of the Orbi router with fully dynamic ips. The Environment has run with this config for months and months without HomeKit issues. I’m a big fan of keep it simple.
It is difficult to single Orbi out exclusively as the iOS platform itself has also just gone through an update cycle. Crossing fingers for now.
For the record and clarity, fresh firmware factory reset with no bemaform, mu-Mimi, daisy chain, etc...
OK, let us now how it goes.
bsholbrookwrote:For the record and clarity, fresh firmware factory reset with no bemaform, mu-Mimi, daisy chain, etc...
- Mayhugh1Apr 04, 2018Apprentice
FUrrye38,
Are you somehow connected with Netgear?
- usahaleApr 05, 2018Star
Agree. Homekit got hosed with the new firmware. Back to stable version.
- stangebelmApr 05, 2018Guide
Ich verstehe das alles nicht warum macht ihr alle einen Factory Reset? Einfach die neue Firmware ordnungsgemäß abspielen und fertig ist!
Und falls er nicht alle Satelliten erkennt einfach noch mal den Router neu starten fertig aus!!
- FURRYe38Apr 05, 2018Guru - Experienced User
In English please...
stangebelmwrote:Ich verstehe das alles nicht warum macht ihr alle einen Factory Reset? Einfach die neue Firmware ordnungsgemäß abspielen und fertig ist!
- Sdiver2489Apr 05, 2018Apprentice
Ich verstehen sie nicht was du hast gesagt (Sorry I'm just trying out my high school level german where I see an opportunity) How close did I get?
Some of us haven't taken german so no sprechen ze deuch. Please state your post in English since this is an English forum. Thank you.
FURRYe38wrote:Some of us haven't taken german so no sprechen ze deuch. Please state your post in English since this is an English forum. Thank you.
Relax....all I told him is that "I don't understand what you said"...or something like that..
Google translate does a pretty good job on his post:
I do not understand all this, why are you all doing a factory reset? Simply play the new firmware properly and you're done! And if he does not recognize all the satellites just restart the router!
I agree somewhat, I have had issues with other routers getting corrupted with carrying over settings.
/google translate
And if he does not recognize all the satellites just restart the router! - FURRYe38Apr 05, 2018Guru - Experienced User
Not bothered or anything so I'm relaxed. LOL. Just saying, users can please type in english when they post. Google has a good translator they can use before hand then copy and paste too. :smileywink:
Anyways, Yes, factory reset IS needed for now. At least with this v2.1.3.x Betas and such. Theres changes in FW between versions that seem to be causing problems with exhisting configurations. So users need to factory reset there systems fully to clear them out. FULLY! Then setup from scratch while this FW is in flux. Was told that NG is aware of this issue and users will be able up upgrade FW with out resets in near future FW versions.
- Retired_MemberApr 05, 2018
Updated to 2.1.3.4 yesterday without knowing about the need for a factory reset. I'm running everything without resetting and without a glitch (RBR50+RBS50). *knocks on wood*
- rhester72Apr 05, 2018Virtuoso
Retired_Memberwrote:Updated to 2.1.3.4 yesterday without knowing about the need for a factory reset. I'm running everything without resetting and without a glitch (RBR50+RBS50). *knocks on wood*
From which version?
Please let us know if it's solid for more than a week - both my router and satellite rebooted at the same time 8 hours after upgrade, which was a shame because everything else was working very well (no issues with speed/bandwidth, no issues with UI, no latency issues between satellite and router - all was well, at least in AP mode) right up until it wasn't.
From which version?
I was coming from 2.1.2.18 if I remember the sequence correctly. I know for certain it ended with .18. I've read somewhere that particular firmware was pulled from the servers but it functioned nicely for me. In fact, need to knock on wood again, I haven't had any problems with my Orbi set since I bought them 14 months ago. If I remember I'll let you know how I fare with 2.1.3.4. So far, so good.
If your running well with out any problems, then don't reset. If you seem to run into something. Please consider a reset and set up everything from scratch.
- loomis1975Apr 05, 2018Luminary
Finally upgraded to 2.1.3.6 on the RBR40 and 2.1.3.4 on the RBR50 and RBS50 when they released the beta RBR40 firmware. RBS50Y is still on 2.1.2.20. The RBR40 downstairs is daisy chaining through the outside RBS50Y to the router, since something in the floor/ceiling between my living room and den absolutely attenuates wifi signals to almost nothing trying to pass through. I was so glad daisy chaining was released. I used the Orbis mostly at another place and Velop here because of that reason alone. That and the internet provider use to be faster at the other place, but now is fastest at my main residence, so they are swapped now.
This is coming from 2.1.2.18 on the main units, where I didn't have any big issues with performance. I have all the bells and whistles turned on, but only a few devices I have are capable of MU-MIMO and I really am unsure if they are actually using it. Did not have to reset as I am not seeing any degradation in the time since switchover.
The only thing outstanding (this has been the case for over a year, if not longer) that I think is interesting is that Samsung smartphones (S7 and S8) seem to want to use 2.4 ghz instead of the 5 ghz most of the time even when in the same room as router/satellite. When you manually turn wifi off via the phones, then back on, they will usually connect to 5 ghz, but over time end up at 2.4 ghz no matter where they are located. (Smartswitch is turned off on all 3 S7s,S8) No clue why, but not the biggest deal in the world. We are more of a laptop/tablet and above household when it comes to streaming HD video, so it hasn't been a big issue. An Alcatel Idol 4s Windows 10 Phone (I know, I'm trying to hold back the ocean by still using a Windows 10 phone) doesn't have that issue.
Curious, did you do a factory reset and set up from scratch or just update FW and continue?
loomis1975wrote:Finally upgraded to 2.1.3.6 on the RBR40 and 2.1.3.4 on the RBR50 and RBS50 when they released the beta RBR40 firmware. RBS50Y is still on 2.1.2.20. The RBR40 downstairs is daisy chaining through the outside RBS50Y to the router, since something in the floor/ceiling between my living room and den absolutely attenuates wifi signals to almost nothing trying to pass through. I was so glad daisy chaining was released. I used the Orbis mostly at another place and Velop here because of that reason alone. That and the internet provider use to be faster at the other place, but now is fastest at my main residence, so they are swapped now.
- tizmagikApr 05, 2018GuideI’ve tried this firmware for a few days now and while the dropped internet connections have seemed to stop happening I am now noticing intermittent bandwidth issues. I notice it mostly when watching YouTube TV via my Apple TV 4th Gen. It will go from crystal clear 1080 HD to a really abysmal pixelated picture for a few seconds then jump back to clear HD. It happens about once every 5-10 minutes.
Here’s hoping the next version addresses this issue. Happy to also help by providing any logs or anything if that would be useful. - FURRYe38Apr 05, 2018Guru - Experienced User
Did you factory reset the router and satellite(s) after the FW update? If not, try this.
Here’s hoping the next version addresses this issue. Happy to also help by providing any logs or anything if that would be useful. - tizmagikApr 05, 2018GuideThanks for the reply. I did factory reset the Satellite but not the Router. I will try that when I get a chance, although it’s a shame if that were to be necessary :(
Ya, some are having luck with out having to reset. Some, have to reset it all.
tizmagikwrote:
Thanks for the reply. I did factory reset the Satellite but not the Router. I will try that when I get a chance, although it’s a shame if that were to be necessary :( - loomis1975Apr 06, 2018Luminary
FURRYe38 wrote:Curious, did you do a factory reset and set up from scratch or just update FW and continue?
Just update FW and continue. Working like a charm so far. Router uptime is at 2 days now.
- FURRYe38Apr 06, 2018Guru - Experienced User
Kewl, ur a lucky one. Keep it going for now. if you notice problems, give a reset a try.
Enjoy.
loomis1975wrote:Just update FW and continue. Working like a charm so far. Router uptime is at 2 days now.
