AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
bsholbrook
Apr 08, 2018Apprentice
After completing the firmware and a full factory set leaving daisy chain, Mimo, etc offf.... I’m Seeing two themes with this firmware....
First, devices that are on the network 24*7 are randomly dropping connection once per day for 5 to 8 mins. Observed with both nest cameras and ecobee thermostat that have had solid connections for the past 6 plus months. This isn’t the end of the world, but certainly annoying.
second, the firmware looses stability after operating for 72 or more hours. Today for the second time since the firmware release the entire house of 35 devices lost connectivity until the router was reset (no other changes were made to anything. Again this was not observed behavior in the past the Orbiswould operate for weeks. Total connectivity loss like this is a huge problem given the reliance of being a cord cutter with security and home automation.
dont want to spend the money for alternatives, but im on the verge of doing so.
- FURRYe38Apr 08, 2018Guru - Experienced User
What channels are you using on the router, if auto, set manual channels 1, 6 or 11. Find one of those channels with least amount of neighbors using them. Find any unused channel on 5Ghz.
How big is your home? Sq ft?
What is the distance between the router and Satellit(s).
Did you disable beamforming and IPv6 as well?
How many devices do you have connected?
What are they?
Whats your ISP modem Mfr and Model#?
bsholbrook wrote:After completing the firmware and a full factory set leaving daisy chain, Mimo, etc offf.... I’m Seeing two themes with this firmware....
- bsholbrookApr 09, 2018Apprentice
Furry, I've provided all of those details and more on mutiple occasions. While I dont expect your to remeber each post, its old seeing 200+ posts on provide a complete reset etc etc.... we know this, we are doing this and still having issues!!!! If the Orbi ecosystem is this fragile in terms of the surrounding environment then that is even more reasont to move on.
While I totally feel that Costco shouldn't bear the burden in this case this will be the first time I reach out to them in request of a refund for a product months after purchase. There are simply too many nuiances and not enough resolutions to continue on this course.
- FURRYe38Apr 09, 2018Guru - Experienced User
IF you think the Orbi ecosystem is the only thing effected by surroundings, you will be mistaken. Any wifi router and wireless devices can and are effected by surroundings and environments. It's the nature of the beast.
I appologize if I repeat myself sometimes. Just making sure ALL options have been tried is all. Ya, I don't remember all these posts.
bsholbrook wrote:Furry, I've provided all of those details and more on mutiple occasions. While I dont expect your to remeber each post, its old seeing 200+ posts on provide a complete reset etc etc.... we know this, we are doing this and still having issues!!!! If the Orbi ecosystem is this fragile in terms of the surrounding environment then that is even more reasont to move on.
