AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
doccelo
Apr 08, 2018Star
doccelo wrote:Thanks, Netgear team. I'm on 2.0.1.4 currently and having disconnect issues. Will download betas now and report back after some time testing it.
I am still having issues with the router losing internet connectivity and in order to restore functionality I have to reboot the system manually. I've tried every suggestion I could find on these forums to no avail. It seemed stable for a while, but the issue of losing internet connectivity has returned and actually seems to be happening more frequently. Not sure where to go from here... (Yes, I did factory reset and set up from scratch for those wondering).
Apr 08, 2018Guru - Experienced User
What model Orbi system do you have?
What is the mfr and model# of the ISP modem the Orbi is connected too?
When you say disconnects from the internet, do you mean you loose wifi connections or do you loose both wired and wireless?
There any indication on the routers web page of the internet status when this happens?
Do you still have access to the routers web page when this happens?
What channels are you using on the router for wireless?
Do you have the satellite connected? if so, what distance is the satellite away from the router?
doccelo wrote:doccelo wrote:Thanks, Netgear team. I'm on 2.0.1.4 currently and having disconnect issues. Will download betas now and report back after some time testing it.
- docceloApr 08, 2018Star
The ISP modem is an Arris Surfboard SB6141.
I lost internet today, and couldn't connect either through wifi or wired (wired to Orbi RBR50). I also have two RBS50 satellites set up in wagon wheel pattern around router. I can connect to the Orbi router via web interface when I lose internet connectivity. I didn't check today if the Orbi saw an active internet connection from my modem, but a few days ago when the same thing happened I think Orbi was showing no internet connection on the web interface. Modem and ISP (Xfinity Comcast) both reported no problems. I will keep an eye on this next time it happens just to be sure.
I've been on stock setup for channels...I made no changes to that from initial factory reset and setup.
Two satellites: One is located on same floor one room over but there is a gas fireplace and a wall of books against that wall between router and satellite. Other satellite is one floor down from router and about 30-40 feet to the side. Typical 2x4 wood frame construction. The one downstairs I use mostly for its wired connections to hook up non-wifi devices, but also to reach the "bottom" of the "L"... It's an L-shaped ~3800 sf house, and the router sits at about the middle of the downstroke of the "L".
- FURRYe38Apr 08, 2018Guru - Experienced User
I would only use 1 Satellite and see if this does anything.
I would also power OFF the ISP modem and orbi router for 1 minute and power back on. Then power ON the modem. After it syncs, power ON the router.
I would also swap out LAN cable between the modem and router. Use CAT6. Don't use the cable that came in the box with the orbi system.
I would test with just the router being online only at first. Turn OFF the satellites.
Set manual channels to 1 6 or 11 on 2.4Ghz. Any unused channel on 5Ghz.
Disable Beamforming, MIMO, Daisy Chain, Fast Roaming and IPv6 ON ther router.
Save settings to apply then do a full REBOOT on the router. See how it goes.
Your using older FW which exhibited some issues as well. If these suggestions don't seem to work, you might manually upgrade FW to v2.1.3.4 if it's still available.
doccelo wrote:The ISP modem is an Arris Surfboard SB6141.
Thanks for your help FURRYe38.
FURRYe38 wrote:I would only use 1 Satellite and see if this does anything. I will try this.
I would also power OFF the ISP modem and orbi router for 1 minute and power back on. Then power ON the modem. After it syncs, power ON the router. I've done this multiple times, and in that sequence.
I would also swap out LAN cable between the modem and router. Use CAT6. Don't use the cable that came in the box with the orbi system. I'm using CAT6 cables and not the ones that came with the Orbi. I might try to swap out cables again for another just to rule that out (but I've never had issues with a previous Asus RT-AC87U). Might try to set that router up and put Orbi into AP mode, although I bought the Orbi to replace the Asus not supplement it.
I would test with just the router being online only at first. Turn OFF the satellites. After the last internet drop, I actually did exactly this and am running just the router right now to test.
Set manual channels to 1 6 or 11 on 2.4Ghz. Any unused channel on 5Ghz. Will try this.
Disable Beamforming, MIMO, Daisy Chain, Fast Roaming and IPv6 ON ther router. All were disabled already, including IPv6.
Your using older FW which exhibited some issues as well. If these suggestions don't seem to work, you might manually upgrade FW to v2.1.3.4 if it's still available. I upgraded to the 2.1.3.4 beta the day it was released. Been running it since.
