AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
PyroDog
Mar 23, 2018Apprentice
So I gave this beta a test run and disappointingly the packet loss issues are still there. As you can see from the graph, the communication hangs at regular intervals. This is a 10 minute graph with a massive 16.8% PL. For this test I tried several configuration combinations, factory reset and disconecting all devices from the network in order to isolate the issue to the Orbi devices. I have been doing this for each firmware version since 2.0.0.74
This issue began wirh firmware V2.0.1.4 with only a mild PL issue. Newer firmwares have been just as bad as the current beta. Fortunately I don't need Circle or ethernet backhaul so I'm goinga back to V2.0.0.74 for the time being.
Apr 08, 2018Guru - Experienced User
And what is the Mfr and model # of the ISP modem your using with the orbi system?
PyroDog wrote:So I gave this beta a test run and disappointingly the packet loss issues are still there. As you can see from the graph, the communication hangs at regular intervals. This is a 10 minute graph with a massive 16.8% PL. For this test I tried several configuration combinations, factory reset and disconecting all devices from the network in order to isolate the issue to the Orbi devices. I have been doing this for each firmware version since 2.0.0.74
