AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
SkippityDDoodah
Apr 09, 2018Initiate
We just purchased Orbi Router Mod. RBR20 & RBS20 and they are VERY slow. Why is that?
We replaced an older model Cisco router and before it died, it was MUCH faster than this Orbi. I followed the set-up instructions and your page came right up, but then when I tried to get online, it took forever. It is VERY slow loading. What's up?? Any help would be greatly appreciated.
Mahalo - Skip
- FURRYe38Apr 09, 2018Guru - Experienced User
Please create new post regarding your model Orbi and give more details to the problem here:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
This thread is for other Orbi models using this version of FW, which yours is not supported currently.
SkippityDDoodah wrote:We just purchased Orbi Router Mod. RBR20 & RBS20 and they are VERY slow. Why is that?
Mahalo - Skip
- BluegridApr 23, 2018Aspirant
Hi SkippityDDoodah,
Did you test RBR20 with Ethernet connection first? did you get slow result via Ethernet, too?
If you got good result from Ethernet, can you change a wireless client to see if you can get better throughput?
