AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 09, 2018Guru - Experienced User
After updating FW, did you factory reset both router and satellite and set up from scratch? This is needed for this beta version of fw.
How far appart is the router from the satellites?
How big is your home? SQFt?
Try disabling MIMO, Daisy Chain, Fast roaming and IPv6.
What is the Mfr and model# of the ISP modem?
wegunterjr wrote:Starting today, was running 2.1.2.8 (the first one that could use circle parent controls) and had intermittent network issues. Also, was unable to do speedtest from the app or from the router web access. I haven't turned anything off or messed with anything, just looks like the satellites are dropping, or maybe the main router. Either way, i normally get a 250Mbps speed test, but it was down to less than 1Mbps and after updating to 2.1.3.4 I can get it up to 25Mbps... but still not 100%. Thoughts?
wegunterjr
Apr 09, 2018Guide
That was it! Thanks a ton. I didn't do a factory reset after updating. All good now!
- wegunterjrApr 10, 2018Guide
I should be more clear...all I did was the factory reset. I didn't turn anything off.
I did enable circle and now it seems that I have to setup a new instance since I don't know how ot move the profile...
- FURRYe38Apr 10, 2018Guru - Experienced User
Yes, you'll probably have to set that up again. I don't know if you can move profiles. Something you might contact NG support and ask about. I don't use Circle.
wegunterjr wrote:I should be more clear...all I did was the factory reset. I didn't turn anything off.
checked to make sure, thought it was enabled, but it wasn't.
I enabled Disney Circle and my existing setup from my app was remembered.
Awesome! so far, so good with 2.1.3.4
