AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
LeinieDrinker
Apr 10, 2018Aspirant
I purchased an Orbi RBK53 from Costco (3pk) last Friday.
Love the overall coverage I am getting, but I am getting serveral drops/disconnect from the Internet. I am using an Arris SB6183 with Xfinity Internet.
I keep reading on here that people are having better luck with a beta firmware, but when I go
to the support page for my Orbi I don't see anything listed as Beta.
Any help to direct me towards a firmware that would help with my issues would be
appreciated.
wegunterjr
Apr 10, 2018Guide
This is the link to the beta firmware:
https://kb.netgear.com/000055562/RBR50-RBS50-Firmware-Version-2-1-3-4
- LeinieDrinkerApr 10, 2018Aspirant
Thanks for your reply. I have updated my router and satellites
to V2.1.3.4. I hope this helps.
- FURRYe38Apr 10, 2018Guru - Experienced User
Its recommended to factory reset and set up from scratch after updating to this version of FW. Hope it works well for you.
Whats the size of your home? Sqft?
What is the distance between the router and satellite?
LeinieDrinker wrote:Thanks for your reply. I have updated my router and satellites
- Mikey94025Apr 10, 2018Hero
Count me in for one of the lucky people with a very stable V2.1.3.4 installation. My home environment + devices is such that I have no problems. My uptime per http://orbilogin.net/debug.htm is 17 days. Can anyone beat that? :smileyhappy:
Number of Satellites: 3Number of devices: 54CPU Load 7.38916% Memory Usage(Used/Total) 195MB/495MB Flash Usage(Used/Total) 32MB/4GB Network Session(Active/Total) 1146/65536 System Uptime 17:02:55:02 BTW, I'm lazy and have not been doing factory resets before each firmware upgrade/downgrade. So far it's been working fine for me, but if I ever experience any performance issues then I would try factory reset.
Thanks for posting your expriences. Good up time...Lots of devices too. Wow.
Enjoy.
Mikey94025 wrote:Count me in for one of the lucky people with a very stable V2.1.3.4 installation. My home environment + devices is such that I have no problems. My uptime per http://orbilogin.net/debug.htm is 17 days. Can anyone beat that? :smileyhappy:
