AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Chairman007
Apr 12, 2018Star
Just installed the beta firmware v.2.1.3.6 for my RBW30 wallplug satellite. Previously did the Reset .... I can confirm that this round of firmware looks very good in terms of stability. Daisy chain, Ethernet backhaul, Beamforming & Fast Roaming are all enabled. Everything working fine now. Only minor issues observed like inability to do the Speed Test ... my guess is this will get re-enabled down the road.
- mmiguyApr 12, 2018Aspirant
Ok, questions on the 2.1.3.4 FW upgrade.
1. Since this is a beta, do I have to reinstall again once the final version is released? Is this imminent or will it take months to be released? My system is dropping wireless devices constantly so I have to do something.
2. I have 2 wired runs for the Ethernet backhaul for the 2 satellites with no switches in between those and the main router. I am on 2.0.1.4 currently so the ethernet lines are not connected yet. What are the step by step instructions to do this upgrade correctly given the way it is configured?
- FURRYe38Apr 12, 2018Guru - Experienced User
Let us know how it goes. Should work well for you.
Yes, Ng is aware of the speed test issues.
