AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Chairman007
Apr 12, 2018Star
Just installed the beta firmware v.2.1.3.6 for my RBW30 wallplug satellite. Previously did the Reset .... I can confirm that this round of firmware looks very good in terms of stability. Daisy chain, Ethernet backhaul, Beamforming & Fast Roaming are all enabled. Everything working fine now. Only minor issues observed like inability to do the Speed Test ... my guess is this will get re-enabled down the road.
Apr 12, 2018Guru - Experienced User
Let us know how it goes. Should work well for you.
Yes, Ng is aware of the speed test issues.
