AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 12, 2018Guru - Experienced User
Ya, wireless or VPN would not be recommended for doing FW updates. Next time, you might have someone more locally help out on site if a FW is needed. Glad the reset got it working again. Enjoy.
ktula wrote:I updated the router to 2.1.3.4 from 2.1.2.8 via remotely-VPNed to the router. I would strongly recommend against doing what i did. During the update process, i believe the firmware got corrupted so i could no longer VPN to it. Because i was thousands of miles away, there was no way for me to fix it remotely. When i got back home, i could see the SSID of the network but i could not connect to it. I had to factory reset the router and both satellites and configure them from scratch. Everything appears to be working OK now.
angr
Apr 12, 2018Star
I've upgraded my system (RBR50, RBS50, 2x RBS40, 1xRBW30) to the latest BETA. Only upgraded RBW30 just now, however for the other parts of my system (running the latest FW beta for slightly less than a week now) this has been the best and most stable release for me in a very long time!
I used to have intermittent issues with individual wifi clients losing connections (and sometimes refusing to reconnect properly without satellite/router reboot) while other clients also connected to the same router or satellite were continously working just fine. My wife's Macbook were one of the most heavily affected by this, and have been for a long time - and believe me that was not easily managed. :P
I'm very happy to say that this seems to be a thing of the past now.
- MilmalApr 12, 2018Aspirant
What beta are you refering to in relations to RBK40?
- FURRYe38Apr 12, 2018Guru - Experienced User
Glad its working well now. Enjoy.
angr wrote:I've upgraded my system (RBR50, RBS50, 2x RBS40, 1xRBW30) to the latest BETA. Only upgraded RBW30 just now, however for the other parts of my system (running the latest FW beta for slightly less than a week now) this has been the best and most stable release for me in a very long time!
