AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Apr 13, 2018Guru - Experienced User
Have you factory reset both router and satellite and reset up the circle app again?
wegunterjr wrote:With 2.1.3.4 update on the RBR50, RBS50 - seems to be working, but I am noticing an error in Parental Controls -> Disney Circle- it is now saying cannot connect to device. I updated a few days ago, and circle app on my phone connected again, but now it is not.
THoughts?
wegunterjr
Apr 13, 2018Guide
I factory reset the router, but not the satellites. How do you reset those?
I did renable Disney Circle and then connected to it from the app..not sure if i did that right...
- FURRYe38Apr 13, 2018Guru - Experienced User
Back pin hole on back of satellite.
You might try setting up the app on the router using a PC and browser and see if this helps.
- rhester72Apr 13, 2018Virtuoso
You guys might have read where I was engaged by Netgear support early this week, and that their direction is what you've already heard - upgrade to 2.1.3.x, factory reset with paperclips on satellite and router, and start over.
I can't explain it (I'm an ex OpenWRT dev, so I'm intimately familiar with how things work under the hood), but sure enough - it worked. The random 12-hour restarts are gone. I've been rock-solid in AP mode since Tuesday morning, perfect performance and latency, not a single packet drop (I'm explicitly monitoring for this 24/7).
For those who have said "a reset won't help, been there done that", "I can't be bothered to reset", etc. - I feel your pain. It's a serious pain in the butt to start over - but for whatever reason, on this code branch, it's necessary and worth it. Bite the bullet - upgrade, reset (I did Satellite first and then Router, but I doubt it matters - just reset EVERYTHING _before_ you start to reconfigure), and go. Upgrade *first*.
Good luck (and hope you won't need luck)!
Thanks for letting us know. Glad the reset helped. Been saying this all along.
rhester72 wrote:You guys might have read where I was engaged by Netgear support early this week, and that their direction is what you've already heard - upgrade to 2.1.3.x, factory reset with paperclips on satellite and router, and start over.
