AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
tizmagik
Apr 17, 2018Guide
FURRYe38 wrote:What channels are you using? Try manual channels 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Set 20.40Mhz Coexistence to 40Mhz only.
Have you tested with MIMO, Daisy Chain, Fast Roaming and IPv6 disabled?
tizmagik wrote:FURRYe38 wrote:Did you factory reset the router and satellite(s) after the FW update? If not, try this.
tizmagikwrote:
I’ve tried this firmware for a few days now and while the dropped internet connections have seemed to stop happening I am now noticing intermittent bandwidth issues. I notice it mostly when watching YouTube TV via my Apple TV 4th Gen. It will go from crystal clear 1080 HD to a really abysmal pixelated picture for a few seconds then jump back to clear HD. It happens about once every 5-10 minutes.
Here’s hoping the next version addresses this issue. Happy to also help by providing any logs or anything if that would be useful.
I've tried a factory reset of both the Router and Satellite and am still having periodic streaming issues for YouTube TV. It's happening for both my Apple TV (4th Gen) and my Xbox One, so it's not specific to one device.
Thank you. I will try that and post back.
Apr 17, 2018Guru - Experienced User
Keep us posted...
