AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
turns2stone
Apr 20, 2018Apprentice
FURRYe38 wrote:Let us know if power cycling the switch does anything. Odd that the satellite works drirectly connected and doesnt with this switch and LAN cabling in the mix...
Didn't help, or change the behavior :( There must be some odd combination of resets/power-cycles that I'm not doing correctly. System seems more stable now on 2.1.3.4, and I don't think my iPad Pro 9.7 has been kicked off with this firmware, whereas it was a daily occurance before I upgraded.
Apr 20, 2018Guru - Experienced User
Could be something in the iOS as well on this iPad.
