AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Planetom
Apr 21, 2018Star
When will there be a new firmware?
This piece of **bleep** just isn't working
(yes I treid it all several times all configs multiple resets)
Apr 21, 2018Guru - Experienced User
You might contact NG support and ask for an RMA, you may have bad HW that FW can't fix.
Planetom wrote:When will there be a new firmware?
- CyberExorcistApr 22, 2018Star
FURRYe38 wrote:You might contact NG support and ask for an RMA, you may have bad HW that FW can't fix.
I will echo what FURRYe38 is stating. I had a lot of problems and just received a new satellite from Netgear, via RMA. I'm hoping it was a hardware issue. All of my issues seemed to stem from the satellite itself and not the router (ie. I could unplug the satellite and not have any issues). The next week or two will be the deciding factor.
