AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
diarmuidma
Apr 21, 2018Star
I definitely think this version is less stable on older orbis.
I managed to capture a Oops kernel crash shame netgear dont have support that wants feedback or pre beta community testers so we could help fix issues. I'm sticking with old much more stable firmware.
RogerSC
Apr 21, 2018Virtuoso
My Orbi was purchased back in 10/2016. Doing fine on 2.1.3.4 after about 1.5 years. Is that old enough *smile*? Anyways, I agree about Beta testing firmware. I've seen that Netgear does that with people that are having problems, but I don't know how much Beta firmware testing they do with people that aren't currently having problems. Seems like that would be a good thing to do as well, to catch oncoming problems before those problems are auto-updated onto all our routers. I, for one, would be happy to Beta test new firmware. It's in my interest to do that, and I enjoy Beta testing.
- timchApr 22, 2018Luminary13 days now and not a glitch. Performance is very fast but then again I’ve not had problems on previous firmware versions. Hope others are now joining me in the ranks of very satisfied customers.
- globespyApr 22, 2018Apprentice
I'm probably getting close to a month without having to touch anything!
I'm seeing higher WiFi speeds than often reported by Cat6 wired devices.
I have had Google WiFi - garbage.
I had the Velop, which was excellent.
I had avoided the Orbi because of the bad feedback - plus I don't have a great history with Network and their sub-par 90 day tech support among other issues.
But this thing is a beast. I don't want to touch the FW - V2.1.3.4 is how this should be and I am hoping because it was a 'beta' that I might be able to avoid any updates.
If it ain't broke.....
- FURRYe38Apr 22, 2018Guru - Experienced User
Hopefully going forward when updates are pushed, shouldn't need any factory resets and set up from scratch either. Should only be needed as a last troubleshooting step from here on out.
globespy wrote:I'm probably getting close to a month without having to touch anything!
