AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
turns2stone
Apr 23, 2018Apprentice
What are the chances that an upcoming 2.2.x firmware will improve wired backhaul? Because I cannot get this to work, unless the satellites are directly connected to the Orbi router. And my switch/cabling in between the router/satellites has never caused any problems in the past 5 years.
Maybe an even more important question: how much improvement have you guys seen going from RBR50->RBS50 Wi-Fi backhaul performance to wired? My Orbis are max 40 feet from each other. Most of my iPhones/iPads/laptops have up to 866Mbps antennas/performance. I can easily get 300-500Mbps (I do have 1Gbps internet service). Going from the 1733Mbps (real world 800Mbps throughput max?) backhaul, to wired Cat6, is it realistic to expect 400-600Mbps Wi-Fi performance on devices that support 866Mbps?
