AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
wegunterjr
Apr 23, 2018Guide
I am having issues with connecting to a VPN. I usually connect to my work VPN using CISCO AnyConnect - I have been able to do it, but I think it was prior to the update. THoughts?
Apr 23, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem?
If you updated FW v2.1.3.4, was a factory reset and set up performed? if not, please do this and set up from scratch.
wegunterjr wrote:I am having issues with connecting to a VPN. I usually connect to my work VPN using CISCO AnyConnect - I have been able to do it, but I think it was prior to the update. THoughts?
