AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
UnhappyOrbiUser
Apr 23, 2018Star
AmitR wrote:BETA MR 2.1.3 software can be found here:
RBR40: http://files.netgear-support.com/go/?a=d&i=NWHSwvM06n
That link does not work, or no longer works, whichever.
2.1.2.18 + 2.1.2.2 (RBW30) has been a nightmare.. is there a newer version I can try somewhere, or should I look for an older version?
- b1ggjoeApr 23, 2018Apprentice
Hey Everyone,
I have a RBK50 system that has been performing flawlessly since the day I installed it. I'm using the following Firmware: V2.1.2.18.
Does this Firmware support Ethernet-Backhaul? I haven't tried it yet, so just wanted to ask before I do.
Thanks!
BJ
- FURRYe38Apr 23, 2018Guru - Experienced User
V2.1.3.4 supported ethernet back how. Works well. Its recommended after you update to this verions of FW, do a factory reset on both router and satellite(s) then setup from scratch. Some major changes in this version so it needs a clean slate.
b1ggjoe wrote:Hey Everyone,
Thanks!
BJ
Thank you Sir!! I have a small request:
I've seen so many different recommendations and 'recipes' on what is the best thing to do, as well as the specific order in which to do things, when it comes to updating/upgrading Firmware, the Router first vs. Satellites first and etc.
Would it be possible for you to throw something together that we can all use as a guide for the best way to perform Firmware upgrades and so forth?
Thanks!
BJ
It was here however the file was removed:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584/highlight/true#M26234
Your mest option would be to contact NG support or PM one of the Moderators and ask for v2.1.3.x version for the 40 series model.
