AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
UnhappyOrbiUser
Apr 23, 2018Star
AmitR wrote:BETA MR 2.1.3 software can be found here:
RBR40: http://files.netgear-support.com/go/?a=d&i=NWHSwvM06n
That link does not work, or no longer works, whichever.
2.1.2.18 + 2.1.2.2 (RBW30) has been a nightmare.. is there a newer version I can try somewhere, or should I look for an older version?
Apr 23, 2018Guru - Experienced User
It was here however the file was removed:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584/highlight/true#M26234
Your mest option would be to contact NG support or PM one of the Moderators and ask for v2.1.3.x version for the 40 series model.
UnhappyOrbiUser wrote:AmitR wrote:BETA MR 2.1.3 software can be found here:
