AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
Gelissen
Apr 24, 2018Aspirant
The link on the first page of this topic for the RBS40 BETA MR 2.1.3 firmware doesn't work.
RBS40: http://files.netgear-support.com/go/?a=d&i=SoxDgoIHIg
Does anyone have the right link?
Thanks!
Apr 24, 2018Guru - Experienced User
The 40 series files were removed for unknown reasons. You might contact NG support and ask for the v2.1.3.6 beta files if they will give them to you.
Gelissen wrote:The link on the first page of this topic for the RBS40 BETA MR 2.1.3 firmware doesn't work.
Thanks!
